time2roll
Jan 25, 2015Nomad
Labeled is great and you may still want to map everything out with an outlet tester.
The real issue would be if the converter or fridge is on one of these circuits. My fridge is and must be put to propane only to avoid inverter power.
Right above my inverter switch I put a label '300w inverter, set fridge to propane'.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
