grizzzman
Oct 30, 2015Explorer
E&J push'n wind wrote:
Okay, got the inverter and transfer switch. Went to use it on my last outing and unfortunately my converter is tied to my 120 V outlets. Switch off the breaker for the converter and you lose power to the plugs. What I'd like to do is get another junction box with 7 breaker spots. There was a breaker for the microwave, the converter/outlets, Water heater, A/C,GFCI and then of course the main. I need one more space so I can tie the outlets to that one so the converter stands alone. Then I can run my inverter without the converter trying to run too. Any ideas where I can get an AC/DC 30 amp junction boxfor my TT?
I would suggest that you tie the converter power to the "power cord" at the transfer switch. This would need a fuse but it would solve your problem with out adding a sub panel.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
