Naio wrote:
Thanks Roy Ken and GdeTrailer for the two options and the very clear illustrations! I know those took time and effort, especially Roy Ken's.
A simple way to get more insulation efficiency: Use a freezer instead of a fridge. Turn it down all the way, and if it still freezes I hear a dimmer switch works.
Using a chest freezer as a fridge can be done but the T stat typically will not have enough range to get it warm enough so the food doesn't freeze..
Off grid folks have successfully modded chest freezers in to a fridge by bypassing the built in T stat and using a PID type adjustable T stat.. Allows precise temperature control and take advantage of a chest freezers efficiency..
Dimming controls are not compatible with heavy induction loads and will either burn up the dimmer or compressor in the process.
On edit..
Found some instructions of converting a chest freezer FYI..
HERE
