2oldman
May 25, 2019Explorer II
600ah of Lithium ..? You could run anything in your coach, and probably your a/c for a while. I'll try to convince you to skip all that work and do it the much easier way: Do a hard-wire whole house install.
Forget the sub-panel stuff, forget the moving the shore cord. Is that Magnum an IC? If so, you've got it made.
a) install an spst switch on the converter and turn it off. If it has a separate breaker, even better, just turn that off. Use the charger in the Magnum. Caveat: Make sure the Magnum can be adjusted to charge Li's
b) Move ac panel's shore input to output of Magnum. Move shore cord power to ac input of Magnum. Most inverters that large have hard-wire functionality. I use household Romex. Did you mean you were going to plug your shore cord into it? I don't see any outlets on it.
c) Done, and you can run anything you want.
Now, having said my peace, if you absolutely cannot remember to turn your HW to gas and your refer to gas when inverting, then forget all this and do it your way.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
