Itinerant1
May 26, 2019Explorer
I have the Magnum 3012 inverter and as suggested a sub panel was added. The new panel had the main, inverter, hot water moved to it making the original the sub panel.
The last time I hooked up to a power pole (50a) I would just flip the hot water switch on in the main panel. This is the hybrid unit so on the me-arc I would adjust the incoming ac to 50a to power everything off of the power pole.
Like yours the panel is in the middle of trailer and the inverter, batteries, pt controller are in the front compartment.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
