CA_Traveler
May 26, 2019Explorer III
time2roll wrote:Also call Magnum and find out if you need a dual 30A CB on the Magnum input to protect the Magnum.
I believe if you feed the full 50 amp split phase through the inverter transfer switch the main breakers in the RV should be swapped down to 30 amps.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
