robertdmunn
May 26, 2019Explorer
time2roll wrote:robertdmunn wrote:I believe if you feed the full 50 amp split phase through the inverter transfer switch the main breakers in the RV should be swapped down to 30 amps.
Good points, thanks. We often connect to shore power at 30A and haven't really had issues with it, but am I limited to 30A in pass-through mode using shore power with a single unit? We don't really need A/C or elec. water heater, so when inverting, 30A is enough.
good point ...
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
