time2roll
Nov 06, 2016Nomad
DLS-90 will work great on AGM. All are DLS with IQ either built in or available separate. There is also an IQ module to link two IOTAs for up to 180 amps charging.
"4th stage" is just a restart of the charging algorithm sequence once a week.
DLS-90 needs monster power. Spec sheet is a bit confusing. Footnote says 30 amp breaker required. Picture says 6-15 plug (240v) but shows a 5-15 picture when even the DLS-75 shows a 5-20 plug. Best to verify before you click and ship. (I just sent an email to IOTA because I want to know)
http://www.iotaengineering.com/pplib/spec2.pdf
I would plan to use the maximum size wire that fits the connectors. Probably #4
