landyacht318
Nov 06, 2016Explorer
I was very annoyed with the voltages my Vehicles voltage regulator chose.
With assistance from Mexwanderer, i bypassed my OEM voltage regulator and now control the vehicle's voltage with an adjustable voltage regulator whose adjustment dial is on my dashboard next to my digital voltmeters.Did someone just hear distant maniacal laughter?
That was Me.
The sterling product linked by grizzman is a dc to dc converter that takes whatever the vehicle's voltage regulator allows, and converts it to 14.x, then 13.x then a lower 13.x for the '3 stage' marketing mumbo jumbo with a 50 amp maximum.
I generally dial in 14.7v, 14.4v or 13.7v ( look three stages!) depending on where my battery state of charge is at, and the battery temperature. My alternator is rated at 120 amps. I've seen it deliver nearly that and my Northstar AGM battery has no issue handling that amount of current when depleted and the alternator is spinning fast enough and I have the voltage regulator cranked to 14.4v +.
No conversion losses. Total price, about 50$ in parts 25 for regulator, potentiometer, wiring and 10 ohm 50 watt resistor to trick engine computer.
Take power from alternator (+) stud rather than engine battery(+). OEM charging circuit is an electrical bottleneck, and taking power from engine battery just adds another circuit onto the end of that already too thin bottleneck.
But,
your Vmax tanks 155Ah batteries claim
There are several dozen different ways and dozens of different products to get alternator juice to house batteries while saving engine battery from house loads with engine off.
You might soon be able to read about all the variable ways to do it in this thread.
I use a manual 1/2/both/Off switch. Blue seas 6007m. I am not keen on anything automatic concerning battery charging. My opinion and preference. Others feel the opposite, and might type louder.
Whatever method you choose, it takes about 3.5 hours for healthy batteries to get from 80% charged to 100% charged no matter how powerful the charging source might be.
Achieving 100% state of charge regularly is the key to battery longevity. The alternator told to make enough power to seek 14.4 volts can get the discharged battery to 80% relatively quickly, but that last 20% takes no less than 3.5 hours, even when held at absorption voltage and with a 50 ampDC to DC converter, or a 120 amp alternator providing the current, whenever the engine is running.
Solar is pretty good at holding 14.4v for those several hours after alternator has gotten them to 80% relatively quickly.
Alternator + sufficient solar could yield good to excellent battery life. The alternator alone rarely can do more than 'poor' to 'fair' battery life when the batteries are cycled deeply, daily.
Being able to plug in for days to give the batteries a chance to reach 100% and also give them a rest from cycling is a big help too.
How long they last and if this time is acceptable to owner is subjective and highly variable depending on depth of discharge and how close to fully charged they get. Only getting to 95% each recharge is not good enough. Even 99% is not day in and day out. That last 1% can take an hour and can double battery lifespan in a daily deep cycle application. The last 1% is especially important with an AGM battery.
That was Me.
But,
MAX. CHARGING CURRENT: 35A MAX. CHARGING VOLTAGE: 14.7V RECOMMENDED: 15A, 14.5V
