newman_fulltime
Nov 12, 2017Explorer II
pianotuna wrote:You are correct which is all to often from the chord connection just hanging on the side of the trailer not using the twistlock ring
Sounds as if there may have been an "open neutral" event which put 240 volts through one leg of the RV.
In other words--the transfer switch may not have caused the failure--but rather was damaged by the failure upstream from it.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
