MrWizard
Jul 02, 2016Moderator
Reflex
It seems you wired it correctly
But a 19 inch TV that only uses 12w, seems like a miracle to me
Although the fan power seems right
There are no stray negative wires connected on the wrong side of the shunt? The only thing on the negative battery post is the shunt?
ALL negative wires are connected on the output far side of the shunt?
Any negative wire connected at the post side instead of the far side will be bypassing the shunt and NOT give a reading on the meter
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
