Reflex439
Jul 04, 2016Explorer
MrWizard wrote:
The shunt is not polarity sensitive, doesn't matter which end is connected to the battery
Try setting the meter at 200 amp
Only 100A and 50A settings :(
I'll live with the meter as is. Regardless of the accuracy of the numbers compared to Wh, at least it will be a far more accurate indication of battery capacity once I cycle the batteries a few times to find out what the bottom range is. I can then use it as a far more accurate and granular gauge compared to the 4 LED stock RV monitor.
Again, thanks for all the help everybody.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
