Reflex439's avatar
Reflex439
Is 100Wh from a standard Group24 battery reasonable?
I don’t know the condition or actual specs on the battery, but its a used battery in a RV I purchased used.
Here is how it is marked;
M24-1 starting marine battery
Marine cranking 625
Cold cranking 500
Reserve capacity 95
When using it, I can get a hour or so running a 19” 12V TV, running the fantastic fan on low most of the night, a couple LED lights, and the refrig on LP setting. In the morning the monitor I have installed shows ~100Wh of energy used, voltage of around 11.8 to 12.0 with a light load (refrig on LP and fan on low), and needing to be recharged.
I am not familiar with watts vs amps over a time frame, so I don’t know if 100Wh is typical for a Group 24 battery before needing to be recharged. Does this seem normal for similar batteries? If not, what might be considered more reasonable for a Group 24 deep cycle battery? 1.5x, 2x or ???
Currently this is the only house battery installed, other than the vehicle battery which is isolated. I have just enough room for two side-by-side group 24 batteries (see dimensions below).
Just looking for ideas on increasing the current capacity, and hoping for a minimum of a two fold increase. I do not want to modify the existing battery compartment, so the right solution needs to fit in a 14”W x 10.5L” x 9.5”H space
Thanks...
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 21, 2025
