DAS26miles's avatar
DAS26miles
Explorer II
Mar 13, 2017
Is 15' extension cord OK off inverter?
I have a 400 watt inverter that is dedicated solely for use with my Dish ViP211z receiver. It only draws .42 amps or 12 watts as read off my Killawatt and .38amps 10 watts draw off the 12 volt as read from my Xantrex Battery Monitor. So the draw is minimal. I want to run a 15' 16/3 extension cord from the inverter under the sofa to the satellite receiver on the other side of the cabover. I know there would be a great deal of 12v line loss if I mounted the inverter near the receiver. But testing with the Killawatt at the inverter and again using the 15' extension cord, I see no loss and the satellite receiver seems to be working fine.
Is this OK to use this way?
  • Fine electrically. Although I am not real big on cords draped all around. If there is an outlet nearby I would be inclined to get a transfer switch and wire it in.
  • Yes, it's fine. It's always better to extend the AC side over the DC side.
  • DrewE's avatar
    DrewE
    Explorer III
    Absolutely. Using a 120V extension cord, properly sized for the load, on a 120V circuit is perfectly acceptable. Do be aware of making sure the wire is run in a physically safe manner (such that it won't be pinched, abraded, enclosed in thermally insulating materials, stapled through, etc.)
    The voltage drop using the wire on 120V is a tenth what it would be for the same power transfer at 12V (because the current is one-tenth as great). The power loss is one one-hundredth as great, since that's voltage drop multiplied by the current. This same basic principle is the reason why power companies use high voltage transmission lines: it reduces line losses to an acceptable level.
  • No, you have to use ten gauge cable for absolutely everything. ;)
    Seriously, though, I would try it without permanently installing it, just to make sure the thin cord can handle the load under real-world conditions. Does the cord seem warm? Does the Dish receiver use more power under certain conditions, e.g., when watching particularly dense documentaries?
    If there is no appreciable voltage drop, I don't see a downside.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
