MEXICOWANDERER
Feb 06, 2015Explorer
Go down the line BFL and check the voltage across each positive and negative. 12-volts same as always. Charge amperage acceptance is the same too. Chech the voltage differential in each series pair. Unequal voltage equals problems - fix it so each battery in series reads the same. Check this while charging then again at rest
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
