time2roll
Aug 03, 2020Nomad
Check your freeze sensors first. They should be positioned right in where the ice is forming. Access by removing the interior trim. Either way the condensate will flow off the roof unless you have some type of other drain that is plugged.
You may need to post exactly what thermostat brand and model you have. The Dometic units should be switching the high fan when the interior is 4+ degrees higher than the set point.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
