TexasUltra's avatar
TexasUltra
Is A/C on GFCI circuit
I was running on my generator when I tried to plug a small air compressor into the outlet in my exterior storage bay. When I did, the compressor started for a milli-second and didn't run any more. All the breakers appeared to be OK, but I re-set them any way. When I went inside I noticed the A/C was off. It had been on and running fine a few minutes earlier. I checked the GFCI plug by the sink and it would not trip or re-set. I'll change the GFCI plug tomorrow but my question is...would the A/C be on the GFCI circuit?
  • pianotuna wrote:
    My 13500 Dometic is on a 15 amp breaker.
    You haven't specified just which Dometic A/C model you have but here's a typical Dometic A/C Installation Manual and you'll note that 20 amp "circuit protection" (Page 3) is required. I'll repeat - any (properly installed) A/C I've seen has been wired with a 20 amp circuit protected by a 20 amp breaker - 15 amp is insufficient.
    No.
  • Old-Biscuit wrote:
    That outside outlet is.......the A/C should be on it's own 15A CB
    Never seen A/C on a 15 amp breaker, always 20 amp.
  • George3037 wrote:
    Are you sure you didn't trip the breaker on the generator? If you have no power to the GFI the test and reset buttons may not work without power.
    My A/C is on a 20A breaker but on a small generator (say a 2200W gen) its the only thing I can run. If I add more load like a compressor, microwave, large fan etc. it will trip the genny breaker.
    I recently sold my small genny and now have a 3500W Predator or a 4750W Champion that will run everything.
    I thought about this possibility after I parked it back in storage and came home. I'll pull it out tomorrow and check this.
    Thanks
  • A Honda gen will keep running even after its circuit breaker is popped. You reset the CB by stopping the engine and starting over ( with the load unplugged), then plug back in with less load. If big load, start gen engine with eco off then wait till all running then turn eco on or the engine might conk out at first.
    A GFCI will not reset unless it has power. Yours acts like no power, so concur with previous idea, that the gen power CB has popped.
    The A/C should be on its own circuit as stated above, but anything is possible in an RV! :(
  • Are you sure you didn't trip the breaker on the generator? If you have no power to the GFI the test and reset buttons may not work without power.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
