4x4van
Mar 14, 2023Explorer III
3 tons wrote:The <8 amps the OP is quoting is at 12vdc. The 9-9.5 amps you are quoting is 120VAC. Huge difference.
In my view 7-8 amps seems rather high for a evaporative cooler (if I have this right??), and it cost more than a smaller rooftop air conditioner…I see little advantage…
For example, my Coleman 11k btu Mach 1 P.S. uses about 9-9.5 amps with 2 speed fan on low speed, which does a good job, though the fan is a bit noisy…660w of concurrent rooftop harvest (and another 360w ground deployable when stationary off-grid) along with 400a Lithium has been a reasonable combination - Honda 2200 just as a backup, but (except for a periodic run) haven’t used it for air conditioner…
https://www.youtube.com/watch?v=HsgmSaDWUWo
3 tons
The 12vdc evap coolers work well in a small camper without hookups, genset, or inverter/big battery bank, as long as humidity outside is very low (<20%).
