StirCrazy
Mar 15, 2023Moderator
3 tons wrote:StirCrazy wrote:
hi I reacently stubbled across the Fresair web page and was looking at THIS unit. has anyone used an evaporative AC before and how did it work.
I am looking at this for on the camper (no ac or 120V yet) and it would only be a once and a blue moon thing as normaly I am high enough in the mountians to not worry about AC. With the ability to install it in an exsisting 14x14 vent and the low power usage (less than 8amps DC at full power) and the fact it doesnt need pure water so well water or what ever is at the campground would be fine...
Thanks
Steve
In my view 7-8 amps seems rather high for a evaporative cooler (if I have this right??), and it cost more than a smaller rooftop air conditioner…I see little advantage…
For example, my Coleman 11k btu Mach 1 P.S. uses about 9-9.5 amps with 2 speed fan on low speed, which does a good job, though the fan is a bit noisy…660w of concurrent rooftop harvest (and another 360w ground deployable when stationary off-grid) along with 400a Lithium has been a reasonable combination - Honda 2200 just as a backup, but (except for a periodic run) haven’t used it for air conditioner…
https://www.youtube.com/watch?v=HsgmSaDWUWo
3 tons
ya thats the most it can use so would probably be significantly less than that as I wouldnt want a 40 degree drop haha I have no space in this camper to carry a genny and no 120 set up so ya I realize it is a bit pricy but all these 12V setups seam to be for some reason. who knows maybe if I can see one I could make it myself and save some money.
