StirCrazy
Mar 27, 2023Moderator
Sir Lancelot wrote:
Please check out https://www.turbokool.net/Default.asp . Never used one, but thought this style was better than the Fresair version, and less money.
I don't think I would even consider that unit. First, it's a lot taller (over twice the height), but the main reason is it doesn't keep the moisture and air separated. It will put moisture into the air you are putting into the camper. This is why it is so cheap, it's just a humidifier in an airpath. The one I originally looked at said they can make the air colder but not pass the humidity over to the air which ensures you're not pumping wet air into your unit. To me that is worth the extra price if I end up going in this direction. but I will have to check into that more also. but the height difference alone would be my deciding factor.
Steve
