BFL13
Sep 14, 2019Explorer II
wopachop wrote:
So is it 14.8v or 14.7v? I had 14.8v stored to memory but trojan is saying 2.45v per cell.
When you set your meanwell charger to 14.8, what voltage do you measure at the terminals?
Im messing around now charging up batteries and struggling with that voltage drop. Soldered up a new charging lead with thick wires and still getting 0.12v loss.
You will get voltage drop every time anyway. Can't be helped. In the bulk stage with the higher amps there is more voltage drop between charger and battery. Voltage drop is less with the lower amps as they taper during the absorption stage.
You will only see the same voltage at the battery as at the charger when the battery is full and no more amps are flowing.
