BFL13
Apr 19, 2014Explorer II
You have low DC voltage (10-11v)from the converter when on shore power. Before saying the converter is bad, check your 120v voltage in the trailer. If it is less than 105v, you will get that low DC output from the converter.
The slide will work on converter only. It does not need a battery for more oomph (except in maybe some cases) But the slide motor positive wire has to be touching the converter pos wire (use vice grips) since they are not in place together on the battery pos post.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
