westend
Apr 19, 2014Explorer
ib516 wrote:Yes, electronics don't like to be overheated so anything that will let the air flow better inside the case will be a better situation. IMO, the primary cause of failure is probably due to poor component quality or bad solder conditions on the boards.
I think one of the biggest issues is good ole Keystone mounting the fan cooled unit in a closed cabinet with absolutely no ventilation. I will add a couple holes once I can find some grates to cut the holes to size.
I've forgotten which RVnet member repairs these converters but it is probably a simple fix for someone conversant with power supply repair. For that matter, replacing all small components on the boards (if there are no SMD devices) is probably a less than $10 repair.
Good choice on the Powermax replacement, I read good things about the brand.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
