dougrainer
Nov 19, 2016Nomad
12th Man Fan wrote:
I suspect the problem is caused by running both the gas and electric.
I use both for the original start up but after it has reached the proper temp I cut off the gas and the electric handles the recovery just fine.
Cut off your electric and see if the gas doesn't work more like you are expecting it to then.
Doug
LP and 120 uses the same tstat. NO, it should not do that. As another poster stated, odds are the tstat is not tight against the LP aluminum tank. If it is tight, then replace the tstat. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
