mtnbbud's avatar
mtnbbud
Explorer II
Jun 02, 2023
Is replacing the furnace worth it?
I have an 1989 18 ft Terry Resort I've been using for awhile now and enjoy tinkering with updates and such. About 6 years ago, I had pulled out the furnace to attempt to fix a nasty squeak from the fan shaft. After pulling the furnace, I found it was manufactured in such a way that there was no good way to service the motor. I assume the grease or whatever they used to lubricate the shaft had dried up after 30 years of off and on use. I was able to drip some oil along the shaft which worked for a couple of years, but the squeal is back. I also found the furnace is a huge drain on my battery.
When I camp with shore power, I've been using an electric heater. When I need heat when dry camping, I've use a Little Buddy Heater while being careful to monitor with a CO detector and cracking the vents.
I'm currently considering replacing my furnace with a new one. Are the newer furnaces easier on the battery? Would I be able to fit a diesel heater in the spot where the gas furnace used to be while still keeping the external opening watertight?
My Little Buddy Heater has been performing just fine although I hate using those little disposable propane tanks. Being that the cost of a new furnace or quality diesel heater is so high, would it be worth the upgrade?
