Lynnmor
Jun 02, 2017Explorer II
Is there a better dump valve?
I have cable operated Valterra/Bladex dump valves that failed to operate. I know that the cable type can be troublesome, so I explored the reason for the hard operation. I found the cables were not the issue, they moved freely. It turns out that the blade seals pipe to pipe just fine but there is no seal to keep "stuff" out of the area where the blade is when retracted. I sawed the valve apart to verify the fact and it was a mess in there. Given the fact that buildup is inevitable, the life of this type of valve is limited. Of course a direct rod operated one can be used till operation becomes extremely difficult, but a cable will buckle.
I installed tubing from the inside of the new valve and ran it along the cable. If operation begins to stiffen, I will shoot silicone or something into the valve.
If there is a better design out there, please let me know. It appears the electric models just use the faulty design.
