Almot
Dec 16, 2015Explorer III
mchero wrote:
I have a fixture that takes 4 of those bulbs BUT the lower quality bulbs have only one contact/side like the one pictured above. The higher quality have two contacts/side and get a better connection.
Don't remember now, but I think my removed old bulbs also had one contact per side. Try moving the bulb contact to the side a little. The current is low, it's not important to have an ideal contact - any contact will do. As long as the fitting is tight, you're OK. They often make it too much tight, a lot of force is needed to push it into socket.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
