Naio
Jul 06, 2015Explorer II
Dakota98 wrote:Naio wrote:
Thanks Salvo and Phil!
The pulley idea is much interesting.
30 amps charging is ok.
Option # 28
The battery charging system on the EX650 only delivers about 6-8 amps.
You still need a portable "smart" battery charger connected to it.
Do I understand this correctly? It has some sort of charging clips/port, which does 6-8 amps, and then I can plug in a charger to it IN ADDITION? That would be fine. I have chargers up the wazoo.
The talk about subjective loudness is interesting.
Question for you guys: My 120v freezer uses 67w when running, but has a big startup surge (unmeasured). Do I need to bring it with me and try it on the genny, or can I assume it will be ok?
Obviously I would not ask, except bringing it is going to be a PITA :B. The 600w microwave, I can bring more easily.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
