PatrickA51
Oct 07, 2014Explorer
I went over to the RV this afternoon. Generator starts, seems to surge. I again checked the oil , not all the way to full but in the safe zone. I checked the breaker switch,(not tripped)I also checked the altitude adjustment on the carburetor..it was set for 5000ft. I started the generator,(before I started it I sprayed Sea Foam in the carb. I also put a can of Sea Foam in the gas tank. it ran fine, 121v,surged a little bit. I turned the Air Conditioner on it ran for a couple of minutes and shut down for a minute or two, and then started and stopped.I went out and checked the breaker switch, this time it was tripped. Generator still ran no out put voltage. The breaker switch was tripped. I set it started the generator, it runs no out put voltage,now.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
