ksg5000
Dec 04, 2018Explorer II
pauldub wrote:
I looked in the owner's manual for you and didn't not find any service interval for diff fluid. It does say to replace it when the maintenance minder displays code 6. They are called the Stealership for a reason.
Yep - the only problem I have noted is that if you change the oil frequently (as many do) then you don't get oil reminders which I have read says that you never get to the secondary reminders such as differential changes.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
