Golden_HVAC
Dec 13, 2014Explorer
It is very quiet rating, only 58 Db, or less than most cars at idle. 3,100 watt surge rating is plenty to start and restart a 13,500 Btu A/C unit. Actual run wattage for the A/C is around 1,400 watts or less. So you will have excess capacity to charge the battery, run the TV, and other loads.
I have one A/C and normal loads on my 4,000 watt Onan generator that is built into most Bounder motorhomes. They only installed the 5,500 watt models on the larger RV's with dual A/C units. Mine is probably in the 80 - 90 Db sound range, due to the air cooled design, and 3,600 RPM running speed. Quiet was not a design priority. If quiet had been a design priority, they might have used a slightly larger engine and run the RPM at 1,800.
Honda used to make a RV generator that was water cooled, and in 4,000 and 6,000 watt versions. It was REALLY quiet, and that was mostly due to the water cooled engine.
Have fun camping!
Fred.
Have fun camping!
Fred.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
