valhalla360
Jan 18, 2021Navigator
DD716TED wrote:
We use our trailer a lot during the winter and in COLD weather.. Normally we use the propane furnace but it gobbles propane. The trailer is connected to the 30 amp outlet on the park post BUT when we try to use an electric space heater to help, the post breaker often trips when the microwave or other appliance is used.. Any thoughts about connecting a separate power cord from the park 15 amp pedestal outlet/breaker then routing it into the trailer to power the electric space heater??? had to ask
We just turn off the space heater when running the microwave or electric skillet. It's usually only a few minutes so no big deal.
A 30amp should provide 3600w for short bursts but only about 3000w continuously. A space heater will typically be around 1500w. If the water heater is running (another 1500w) and a 250w fridge (on electric)...you are pushing the outlet to the limit, lights, fans, TV and other small loads can easily push you over the 3600w and pop the breaker.
As mentioned, run the fridge and water heater on propane will keep the power draw down and then shut off the space heater while using other high draw items.
Running a line to a separate pedestal will work but as mentioned, many campground operators won't be happy. Particularly if electricity is included in the site cost.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
