wapiticountry
Jan 18, 2021Explorer
Chum lee wrote:Two things: One, it is not YOUR campsite. It is the park's. They have an absolute right to set any rules and conditions they deem fit as long as they do not violate the law. If the park wants to limit pedestal usage to one connection, then one connection is all you are entitled to use.DD716TED wrote:
We use our trailer a lot during the winter and in COLD weather. Normally we use the propane furnace but it gobbles propane. The trailer is connected to the 30 amp outlet on the park post BUT when we try to use an electric space heater to help, the post breaker often trips when the microwave or other appliance is used. Any thoughts about connecting a separate power cord from the park 15 amp pedestal outlet/breaker then routing it into the trailer to power the electric space heater??? had to ask
If you pay for a 20, 30, or 50 amp unmetered space, (electricity is included in the daily/weekly rate) IMO, you can use all the plugs available at the pedestal in YOUR campsite. You can add additional extension cords, if needed. If the campground owner/manager complains, have them move you to (or charge you for) a larger service/space. (which will, most likely, be more expensive) Do not attempt to argue with with people who do not understand how electricity works. Simply move to another campground.
Chum lee
Second, it has nothing to do with understanding electricity. There may be many reasons to not allow additional connections. It may very well be an economic decision or it might be a wiring or capacity issue. Regardless, it is the park's decision to set policies. You do have the right solution, if you don't like the policies, move on.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
