Lantley
Jan 19, 2021Nomad
valhalla360 wrote:Chum lee wrote:
If you pay for a 20, 30, or 50 amp unmetered space, (electricity is included in the daily/weekly rate) IMO, you can use all the plugs available at the pedestal in YOUR campsite. You can add additional extension cords, if needed. If the campground owner/manager complains, have them move you to (or charge you for) a larger service/space. (which will, most likely, be more expensive) Do not attempt to argue with with people who do not understand how electricity works. Simply move to another campground.
You have it backwards.
If you are paying a metered rate, as long as all the plugs go thru the meter and it doesn't start popping breakers, use what you want...you will pay for what you use.
For short term non-metered sites, they typically ask what your RV is (30 or 50 amp). Also, if you read the fine print on the rental agreement, it often mentions using additional outlets. So the owner would be very much within their rights to limit usage to a single outlet.
You might get away with it but that doesn't make it right.
I don't think its a matter of getting away with it. If the outlets are available I have no hesitancy to use them.
However the CG owner has the right to charge extra or ban additional cords. In the end it's their CG and their rules.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
