DD716TED wrote:
We use our trailer a lot during the winter and in COLD weather. Normally we use the propane furnace but it gobbles propane. The trailer is connected to the 30 amp outlet on the park post BUT when we try to use an electric space heater to help, the post breaker often trips when the microwave or other appliance is used. Any thoughts about connecting a separate power cord from the park 15 amp pedestal outlet/breaker then routing it into the trailer to power the electric space heater??? had to ask
You fail to mention the most critical information to answer your question. Is your campground space short term or long term (daily, weekly, monthly, other) AND is the pedestal you plug into metered or not? If it's metered/measured AND you pay long term rates, you will most likely be charged (separately) for every kilowatt of electricity you use. (regardless of the electrical capacity of your trailer) If it's not metered/measured, AND/OR you are paying short term rates, the electricity is most likely included in your short term campground fee.
If you pay for a 20, 30, or 50 amp unmetered space, (electricity is included in the daily/weekly rate) IMO, you can use all the plugs available at the pedestal in YOUR campsite. You can add additional extension cords, if needed. If the campground owner/manager complains, have them move you to (or charge you for) a larger service/space. (which will, most likely, be more expensive) Do not attempt to argue with with people who do not understand how electricity works. Simply move to another campground.
In my 30' Class A MH (30 amp service) I use an additional 25' 12 gauge 3 wire copper extension cord all the time. My 6 gallon gas/electric water heater has a separate 120 volt exterior plug JUST for that purpose. In cold climates I run the extension cord inside and plug it in to a 1500 watt space heater (water heater unplugged) all the time. I'm not interested in hearing from "others" who can't figure this out. Instead, . . . . just do what you're going to do. Hint: In an RV with a 30 amp service, you cannot use ALL the electrical consumers at the same time. You MUST manage your electrical consumption or you'll trip the main breaker at the pedestal or at your load center. (or you'll start a fire) Your choice!
Chum lee
