marc71's avatar
marc71
Isolating 12v current to trailer
I have a 6ga wire running from the battery of my TV to a winch type quick disconnect at the rear of the truck and the corresponding connector attached to the batteries on the trailer. How do I isolate or disconnect this wire when the vehicle is shut off? Im thinking some type of solenoid? Any help on this project would be most appreciated.
  • For $20 you can get a basic 85a relay like yhis one. Connect the trigger circuit to something that's only on when the engine is running. When you turn the engine off, the solenoid opens the charging circuit to the trailer.
    The battery separator is nice, but if you have only one battery in the truck I don't know if I want to let it go down to 12.8v before it separates.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    THat one is bi-directional (Good for a motor home not needed by the O/P but the concept is good. Just you do not need Bi-Directional. one way is ok
    (Since the trailer will NEVER .. then again.. Go with the BI Directional
    I do (on occasion) hook muy car (not isolated) to the motor home to keerp the battery charged by means of the house converter.. Car battery is 5 years old and starting to show signs of age.. If I do not drive it at least 2x a week it shows signs of "low battery" after a week of gathering dust.
    So if your truck does that, You simply plug in overnight and the Bi-Directional charger.. will charge the TRUCK battery.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
