rwagner43
Jul 29, 2014Explorer
You need 12 VDC to operate the circuit board electronics. Whether or not you need a battery depends on your converter. Older converters need a battery to regulate the converter output. Modern converters do not require a battery because the 12 V output is filtered by circuitry in the converter. After you hook up 12 VDC and you find it works on propane but not 120 VAC you might want to check the 120 VAC electrical heater element. I am currently having trouble with one in my old RV.
