mchero's avatar
mchero
Issues with hot water heater
Forgot to get a make/model but do know it's a 10gal.
Just purchased rig & flushed ALL the "pink stuff" out of her & did the bleach treatment. Flushed the system & now have fresh water with a fresh filter installed.
Having issues with the hot water heater now.
I triple checked the bypass valve, Even removed to to verify that it's NOT plugged. Reinstalled.
How water heater fumctions on both LP & AC. It does indeed get up to temp. When turning on the hot water, after verifing the HWH was full I only et hot water for just a second.
While I was working on the bypass valve I did discover the cover over the HWH. With cover removed I'm looking at the backside of the HWH.
Center top rear it looks like a scald preventer, some type of valve on a hose. Perhaps this is my issue? Could this valve be preventing me from getting hot water?
I double checked the water pump. God only knows how that pump was installed, It's way up behind the panel where the gae vales are located. I had to crawl in & lay pn my back in the dump station compartment. Water pump looks to have NO VALE for sucking up antifreeze. Also no screen on the intake side. I "believe" the whole house filter is ahead of the pump, possibly not.
I'll post the make/model this evening.
