- Old-BiscuitExplorer IIIJack under frame next to landing gear......that is where the weight of 5vr is designed to be lifted.
The front cross member is just a side to side support to provide a finished frame for installation of forward compartment/front panel.
It is NOT a lifting area. - DuctapeExplorerJust use the landing gear. With wood blocks below if needed.
Or two jacks if it is the LG you need to work on. + jack stands
. - BFL13Explorer IIPerhaps use the truck bed as a base with some blocks so the jack can reach the king pin? The truck will sag at first, but if the jack then still has enough travel, it should work.
- dbblsExplorerI would use two jacks and place then under the frame near the front legs. Afraid the cross member between the legs would not support the weight.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
