what I would do is drive across a scale while fully loaded for camping and see what you front axel weighs and what your back axel weighs. then find a jackstand set that rated for more than the highest axel. I am assuming that your rear axel is well under 12000lbs haha so the 3 ton pair will work just fine.
there are frame point you can use, but the problem is you have to jack it higher because the suspension will drop a bit. so usually it is faster just to lift the axel. one thing to not which ever you decide to go with put some squares of 3/4" plywood to put under the jack and jackstands incase you have to di it on a dirt road.
