Walaby's avatar
Walaby
Explorer II
Jul 28, 2015
Jacking up TT to remove wheels - Leaf spring tandem axles
Okay, I've got tandem axles, with leaf springs/equalizer. I need to remove wheels to have new tires mounted, not to mention making sure I know how to change tires on the side of the road. Tried lifting up one axle using the leveling blocks, but could not get it high enough to raise the other wheel (same side) off the ground.
So, given these are leaf springs with equalizer, not the torsion axles, should I/do I just use a bottle jack/floor jack to lift up one wheel/axle to take wheel off? I have read various threads and don't want to do something wrong. My owners manual says NOTHING about it.
I believe I just jack up the one wheel/axle with the bottle jack or floor jack, placing it just behind the wheel on the axle mount area, just looking to confirm. Also, I assume I can just use a jack stand to support the axle while I take the wheel to the tire store for the new tires to be mounted and balanced.
Finally, can I do both wheels on the same side in this manner, and then swap to the other side after replacing tires?
Just don't want to damage anything.
Thanks
Mike
Having RV issues? Connect with others who have been in your shoes.24,296 PostsLatest Activity: Aug 05, 2025
