- mobeewanExplorerCan you put some bleach and water in a jug and use the pump winterizing connection and turn the water tank fill valve to pump it into the tank?
- wolfe10ExplorerPut it in the hose. That way the hose as well as RV plumbing and tank will be sanitized.
- rockhillmanorExplorer IIYou should have 2 water inlets.
One you hook the hose to provide water to RV.
And the gravity feed opening that 'fills' your fresh water tank.
Plastic funnel with long flexible end placed into gravity feed opening and pour bleach in which goes directly to your fresh water tank.
6 bucks at any parts or hardware store. It's what I use to get anti freeze directly into fresh tank to winterize the RV. - 1492ModeratorMoved from Forum Technical Support
- I pour the bleach into my empty water hose, then use the city water fill. Open valve to fill fresh water tank and it goes in with no problem.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
