jolvi's avatar
jolvi
Jayco TV antenna
I have asked this question before, sent an email to Jayco got a reply and is absolutely not a great answer. This is the antenna but nowhere can I find any information about it. Have searched thru unit and cannot find documentation for it. So if any of you all have a clue it would be greatly appreciated. Have sent email to vendor no answer yet and Jayco telling me to contact dealer uh that may be a no answer there too. Anyway this is the information.
TV Antenna: Jayco PN 0342149// ANTENNA,TV AM/FM SHARK FIN BLACK-STEINER
Vendor of Antenna: STEINER TECHNOLOGIES LLC
Thanks
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Better yet pry it off and replace with a Winegard Sensar IV
  • On one of the videos (Jay Feather), if the antenna cannot be raised, it is wooded by the air conditioner. Luck of the draw if the stations you want are in the blind arc or not.
    If it is just stuck down, maybe pry it off (Eternabond where it was) and put it on top of the air cond. shroud. You can add a piece of coax to reach there.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    From the looks of it is can not be rotated to seek best signal or raised to improve performance (Sticks on with double side tape)
    So there are only two possible answers as to how it works
    If you have a wall plate with a 12 volt outlet. Switch LIght and antenna conneciton then light on TV ANTENNA selected
    If not then it very likely does not work worth a (Deleted) but hook the coax to the TV and see what you get. or not
  • ScottG wrote:
    What is your question about it?
    If anyone knows anything about it, such as range which this is not our first RV so know that some antennas are better than others but in the packet of documentation there is nothing on it, but hey did find the little pamphlet on the Dometic thermostat and know that when it switches fan speeds there will be a shutoff and then back on again.
  • dougrainer wrote:
    What he wants to know is, HOW does it operate as Jayco gave no manuals with his 2020 Jayco. Jayco has no answer and directed him to his dealer. Even tho I WORK for a Jayco dealer, that Antenna is new and from what I can find out, it is just a small Shark Fin Omnidirectional TV antenna. From its description, will probably have a reception radius of less than 30 miles. Doug
    Thank you very much that is what I get when I call dealer it is new and we have no information on it, well that is not a help. I appreciate your answer helps some.
    Thanks
  • dougrainer wrote:
    Maybe that is why Jayco gave him a not great answer. Since he has not addressed his question on this forum:B Doug
    Remember, Garbage IN---Garbage Out:)
    Exactly there is no manual on it in all the documentation, even down to the CO detector and all, did register the TV and Entertainment and it gave me access to the owners manual, but nothing to be found on TV antenna. So the question is has anyone else had this antenna and have any information about it. If you wish to you can go to Haylett RV videos and see the antenna I am talking about on the the review of the 2020 Jayco products.
  • What he wants to know is, HOW does it operate as Jayco gave no manuals with his 2020 Jayco. Jayco has no answer and directed him to his dealer. Even tho I WORK for a Jayco dealer, that Antenna is new and from what I can find out, it is just a small Shark Fin Omnidirectional TV antenna. From its description, will probably have a reception radius of less than 30 miles. Doug
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
