dougrainer
Jul 31, 2013Nomad
CHECK the TV set up. Some LCD TV's, the DVD Jensen uses a YELLOW video output to the TV, CHECK the back of the TV and see if you have a YELLOW Video input. Some of the TV's do NOT have a Yellow Video input. That means you MUST go into the TV set up and make one of the RGB component inputs the Yellow Video input. Kind of confusing since most TV's have the Yellow video input jack seperate. If you do NOT set the TV to that, it will show in black and white. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
