Hondavalk
Aug 01, 2013Explorer II
dougrainer wrote:Hondavalk wrote:
Had the same problem. Talked to Crossroads, no help. Talked to Jensen and they had a guess that ending up being correct. On my Toshiba tv it had component inputs. That is where you have 3 jacks for the video input and 2 for the audio. The Jensen AWM965 only has a composite output. ie: 1 yellow cable for the video. So for the 3 video inputs on the tv make sure its plugged into the green input. Than I had to go into the tv menu and in the tools was an option to switch the tv's video input from component to composite. Works perfect. Hope your LG is the same
Thanks, I could not remember which component color input (green). As I stated, if you do NOT tell the TV to make that Green input the Yellow for composite, the TV will show only Black and White. Doug
Don't know if your audio cables are also wrong like on my Crossroads but I couldn't play the TV through my ceiling speakers only DVDs . Turns out on the AMW965 the video jack is an output the the 2 audio jacks on the Jensen are inputs. The factory had hooked the Jensen to the TV inputs instead of the TV outputs. Switched and now the tv can play through the ceiling speakers.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
