MFL
Nov 01, 2019Nomad II
noteven wrote:MFL wrote:
The intermittent problem you describe, IMO, would suggest a bad wiring connection. Can you access the speaker connections to verify a good clean contact.
Jerry
I haven’t chased a loose connection yet because increasing the volume on the base unit causes the speakers to speak when they have “cut out”. Can a loose connection cause that? There is no static when they quit or start up again...
Thanks
I can't answer that question, but only letting you know where I'd start looking. In a previous FW my speakers a-b were wired together from factory, would back feed/squeal when set to b. I rewired them each to their own, problem solved. I doubt the people that install many of these electronics have any real training/knowledge.
Jerry
