huron52's avatar
huron52
Just another question on Solar
I have read a lot of threads on solar installs and I have a question or two.
I am thinking of adding solar to my toy hauler. Planning on about 500watts. Also planning on two 6 volt batteries to start then adding another two 6 volt batteries to the mix.
I am not interested in running my air conditioner but might want to have 120 volts to maybe watch TV or something like that.
So, correct me if my thought process is wrong here.
I plan to install solar on the roof, line down to switch then to controller and then to battery bank.
Controller not installed in with the batteries.
Then connected to the batteries, separate line off to a inverter away from batteries to get 120 volts in the cabin area.
I have dry camped for long weekends with just the batteries so 120 volts is not a biggy at this time
  • Sounds good. Just don't let the existing batteries get too old before adding more. About 1 year max.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 08, 2026
