dougrainer
Aug 10, 2016Nomad
You just joined. You need to understand that ALL Motorhomes and RV;s are different. You need to state Year/Brand/Model of RV when you post for help. Usually when you have a 12 volt switch that is HOT to the touch, 2 things can cause that.
1. IF the switch has a light in it, it is normal for those to get hot to the touch
2. IF no light, then the connections on the back side are loose/corroded/burnt and this causes heat build up on a 12 volt switch. Your switch is 12 volts, not 120 volts. Take the switch loose and look at the back and if loose/corroded/burnt, it will be noticeable. The defective circuit will not cause any problems other than if it continues, will blow the 12 volt fuse for that light. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
