garyemunson
Aug 11, 2016Explorer II
Doesn't matter what you plug your motorhome into as long as you do not exceed that amount of current draw. Plugging into a standard 15 amp outlet is perfectly safe when you store your motorhome at the house as long as you are just doing it just to run the battery charger/converter to keep the batteries good. If you intend to use it as a guest room, you need to get an outlet to match the RV's system (30 or 50 amp) installed. I really don't even like to turn my fridge on when plugged into a 15 amp outlet as that plus the converter is getting up there in draw (and generally you can't 'shut off' the inverter).
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
