Almot
Jan 04, 2018Explorer III
Electric car battery works in different conditions, it has (I think) liquid cooling system that drop-in batts don't.
I'm not sure it really goes down to 5%, what you see on display is not necessarily it, they might show you only % of a "usable charge", but I don't have electric car. Common recommendation for drop-in 12V Li, and 24-36-48 batts of scooters, ebikes etc is running it in 20%-90% SOC.
It needs slightly higher bulk voltage, and Float voltage is zero - charging must stop when full. But let's not deviate.
So... Anybody saw 20 lbs Gr31? ;)
Are the RV lithium ion batts ok with standard RV converters?
